Grdi
AR75 hillclimb
Post by Grdi »
Hi all!
I have been reading this forum since 2006 and found very useful info's here. Thanks you all for that :)
Here is my car:
Alfa 75 with 3.0 24v engine from Alfa 164Q4
additionally added:
- 305mm front disc's + Brembo 4pot (from GTV 916 3.0)
- RSR suspension (125kg front/60kg back) with 30mm front sway bar
Here are some pics and video's of my car.
Cheers
8)
http://www.youtube.com/watch?v=EmNxslXw ... r_embedded
http://www.youtube.com/watch?v=5k-Gi6mE ... re=related
lower gear full throttle
Re: AR75 3.0 24v from Croatia
Welcome... :D
That is a very nice 75! i really like the clean original look with the subtle things like the lip under the frontbumper. 8)
Wheels are a nice match too.
Any more pics on the technical side? like the brake-upgrade or the engine? :P
Grdi
Post by Grdi »
Huh I'm quite often here :oops:
technical side...as I wrote engine is from AR164 3.0 24v Q4 (170kW), stock engine but fully refreshed with new parts. Brake setup I took from GTV 916 3.0 (fully the same as first versions of 156GTA and 147GTA) Brembo 4-pot calipers and original 305mm rotors. Adapters are done by friend of mine, he's very skilled with this (his setup is 310mm and bigger 4-pot Brembo from AR166 3.0) and capable to do any kind of brake adapter.
Master cylindar is original and oil hidraulic handbrake will be installed next week, some drift fun :wink:
Car has gearbox from 75 2.0TS but this days I'm preparing to swap for 75 1.8turbo gearbox with approximately 35% lsd. I need little bit longer gears from TS therefore 1.8t should fit good. I'd like to try some more serious gearbox but currently this has to be OK.
During trackdays I realized water radiator is simply too small for this 24v engine. Currently I have new stock TS/V6 12v radiator but volume is too small for 3.0 24v :( Have to find something bigger that can fit, any hint?
Oil radiator currently I don't have but plan is to buy one and install,
Also I'm looking for someone who is experienced with RSR suspension kits? Have some issues?!
8)
Post by la_strega_nera »
I think the Turbodiesel radiator is the biggest one?
1966 GTV
1982 Suzuki "Bathurst" Katana
GregoryV
Post by GregoryV »
Very - Very Nice! :D
20-Years-3-Motors-Later
la_strega_nera wrote:I think the Turbodiesel radiator is the biggest one?
That's definetly true... :wink: Also has twin cooling fans on it if i remember well.
My answer is just make one . Two brass tanks and three rows of flat tube, no more than 12 fins per inch, distilled water with corrosion inhibitor only and no ethyglycol* mix in coolant. Absence of glycol makes the coolant more efficient. Old school stuff but you can't beat the properties of latent heat and water volume.
Guaranteed to even work through DAKAR.
* If you live where water freezes, well, use glycol as recommended in your area in winter. However if your system is bordeline then you should remove the glycol in summer and just use and inhibitor.
...and if you got a brain like JK, don't be tempted to strap an air conditioner in front of your radiator because the power cord is never long enough.
:wall:
xrad
Post by xrad »
somehow I missed your original post..VERY NICE ride!
I have the 2.4 TD rad. Works great!
Grdi
Post by Grdi »
How does it look 2.4TD rad with one TS fan only?
Two original 2.4TD fans is too heavy. I think should work good also with one big TS fan?!
Where to find new alu 2.4TD rad within EU? OK Parts in Germany? Anywhere else in Europe?
What is your experience with oil radiator on 24v? Did you loose some oil pressure when oil rad was added?
Thnx!
It's not alu I think, could be copper painted black. You have to cut the thin metal sheet close to the battery tray. My battery is in the boot, so the battery is not in the way. I'm using a single V6 fan, should be the same as the TS fan. You have to lengthen the fan mount too. The radiator house may have to be lengthen too. I just extended the hose via a short copper pipe section.
Grdi
Post by Grdi »
My car is original 2.4TD and I had (before crash :) ) new aftermarket alu 2.4TD rad (with two fans at that time).
Grdi
Post by Grdi »
I found new 2.0/2.4TD alu rad in Croatia. Yesterday fitted with TS fan...bad picture quality done by mobile phone :roll:
How is it working?
Grdi
Post by Grdi »
fedezyl wrote:How is it working?
Better then TS rad on first look.
The best check would be on track but this has to wait until March/April when new track day season starting...
In a meantime found I have to change thermostat (Part No: 60563989) :roll:
Locked
