Joemart
Re: A new GTV6 2.5 entry into SA Marque car catergory
Post by Joemart »
Hi
As promised here are links to the video's from race day...
The first one is called "alfa gtv3.0 vs gtv3.7 - FARMING" - I hope u can follow the link
http://www.youtube.com/watch?v=Loq4A9dE ... ature=plcp
The next ones are a few short snippets during qualifying in the wet and a few "moments"
There are 3 short video called "quali 4 Midvaal", Quali 3 Midvaal" and "quali 2" midvaal
http://www.alfatrofeo.com/onboards.html
I hope u enjoy :)
Joemart
Post by Joemart »
Hi
Now thinking of phase II of this development... we are reaching end of the season soon.... Nov, so my thoughts are to now go to next "level" :twisted: for next year..
See Pic below of the motor I am thinking of... (at Dom's)..Then maybe a Front mounted box???
Rear view of Possible Phase II
next phase 2.JPG (133.07 KiB) Viewed 8008 times
Front view of possible phase II
next phase 1.JPG (126.18 KiB) Viewed 8008 times
Hey Joe , I thought only the blokes from Oz posted pics like that :D ( not totally upside down)
Must say it's a bit easier on iPad . I will send you some pics to post of what's needed and possible procedure .
Joemart
Post by Joemart »
:lol: ... they were straight when I saw them... must have been my head from night before :oops:
Anyway, below are some pics of the intended route we will be taking (thanks Kevin) for the frount mounted BOX - the pic of the box is missing, on its way soon :wink:
measuring up the parts!!
measuring up.jpg (137.74 KiB) Viewed 7983 times
the cut out and tunnel to be used - will be TIG weleded
tunnel lres.JPG (120.14 KiB) Viewed 7983 times
laser cut flywheel spacer to be used for Gear box front mounted
laser cut spacer.jpg (141.97 KiB) Viewed 7983 times
Comparing the 2 crossmembers for fit and size
comparing crossmembers.jpg (143.69 KiB) Viewed 7983 times
Joemart
Post by Joemart »
one or two pics from the race event last saturday.... I know it will not mean much to most, but I did my PB of 1:17.931 on race day,.... was great!!!!!!
A left hand corner... but front wheels pointing a little right :)
2 nov 2012 a.jpg (118.81 KiB) Viewed 7882 times
Mmmmm ... using a little more than the track!!!
2 nov 2012.jpg (127.11 KiB) Viewed 7882 times
Joemart
Post by Joemart »
and one or two other pics
Kevin's 3.Plenty
Kevin's 3.Plenty
2 nov d.jpg (29.91 KiB) Viewed 7882 times
A Twin Turbo of Jose
2 nov c.jpg (27.43 KiB) Viewed 7882 times
"leading" the pack... Actually finished 3rd in second heat!!
2 nov b.jpg (27.18 KiB) Viewed 7882 times
Joemart , just watched a video of race from a slower car . Your car handles well ( no credit to the driver how it cuts through the field) . If you compare pics there are two shots taken of your car and my car from from exact position . It shows clearly how my front is stiffer than yours ( that does not sound good :oops: ) .
My rear is 65kg , yours 50 kg
My front is 200kg , yours 120 kg plus 24mm torsion bars ( probably = 170kg )
Also I have rs front anti roll and yours is Standard .
Time will tell when front box is in on your car how it affect your times .
Joemart
Post by Joemart »
Hey Kev
Can u post the video please....
Joemart
Post by Joemart »
Race 1 at Zwartkops Video currently being posted at the following (give it to 11 Nov - slow connection, before it becomes available) :roll:
http://www.youtube.com/watch?v=rNoAYECX79g
Should now be on :)
Joemart
Post by Joemart »
Hi All
Been a while since last post :!: ..... But here is a small update - The brakes (courtesy of Kevin) have now arrived and will be ready for installation... great piece of work!!!!!
disk 2
disk 2
brake disk new low res2.JPG (112.11 KiB) Viewed 7794 times
disk
disk
brake disk new 1 low res.JPG (112.02 KiB) Viewed 7794 times
See Post by Kevin on details
calipers 6 pot low res.JPG (85.12 KiB) Viewed 7794 times
dawie botha
Post by dawie botha »
nice
Hey , hurry up and put them on :D
Joemart
Post by Joemart »
Hi Guys
see link to VIDEO on you-tube....(not great quality, or it would have taken for ever to load :cry:
The sound is GREAT...
side exhaust, 2x50mm pipes, into 2x Suppressors, into a "Y" piece, into a silencer and the out into single 63mm pipe, 90 bend and out the side
http://www.youtube.com/watch?v=EUu1cJLQGKI
Must say... LOTS more torque
Will also post some pics
Ha ha after listening again I did not notice the police sirens in the back round when talking about a nice quiet day in Africa . It's kinda like white noise here . :D
This is definitely the best exhaust so far with our group of GTV 's .
Joemart
Post by Joemart »
:lol: - Histerical - did not notice the sirens either!!!!!
