I'm looking into the front suspension for my GTV. I want this to be as low-budget as possible.
Adapting stuff that is allready in the shed is a more costfriendly approach for me. And it happens that i have a set of Bilstein PSS9 coilovers from a Subaru at hand. the struts itself can be quite easily modified i'm told.
In the rear it's not to difficult to make them fit but up front there are some challenges.
While i'm at it it might be a good idea to change some other things in the front suspension as well. custom lower arms are an easy starting point as they will need some form off mounting point for the coilover. flipping the balljoint is a logical thing to do at this point. Since the car runs 17" wheels there's plenty of room inside the wheel for that.
The nose of the car will need some welding and strengthening for this. moving suspensionpoints is also a possibility then, is this a wise thing to consider?
any tips would be appreciated..
gr. remco
