Re: squadragrunn
Looking good , I would heat up and knock the chassis on inside of the arch back . You probably find it will only be about 15 mm on the lip where the inside mudguard ( cavity guard ) . Your white rims are still nicer . :D
squadragrunn
Re: squadragrunn
Post by squadragrunn »
the white rims aren't bad, but they are used quite commonly and weigh a ton, the speedline mistrals are 3pce, realy light and very rare...........and i like them better
-charles-
Re: squadragrunn
Lighter always wins . Your cross brace in engine bay to engine is excellent . Very clever . You have the diagonal brace back to firewall and then combined to keep engine braced . The one does not interfere with the the other . I'm gonna steal that idea , I hope you don't mind .
squadragrunn
Re: squadragrunn
steal away..... :D
i've used aluminium rods wich are treadcut (?) on the ends. all is easely removed. actually , i did it before on the gtv turbo, it realy helps stiffening up. i still want to brace the frontbeam on wich the swaybar is mounted
-charles-
Joemart
Re: squadragrunn
Post by Joemart »
mmmmmm...... I like.... :wink:
squadragrunn
Re: squadragrunn
dank je.....
-charles-
squadragrunn
Re: squadragrunn
last sunday we visited "viva italia" at the tt-circuit assen. lots of nice italian cars, also a few gtv's including 3(!) 3.0 24v's wich is probably about as much as you will get together here in holland
http://www.alfaclub.eu/fotoalbum.php?aid=271
here a movie shot from a 24v
http://youtu.be/1Gw7Pym49Tg
driving amongs ferraris and lambos
http://youtu.be/MEeWH-hFSWw
http://youtu.be/JJ0S5sl9P80
-charles-
squadragrunn
Re: squadragrunn
for anyone interested, the steeringpump of an later model alfa(164) doesn't work well with an steeringrack of the 75, it cooks the oil and after a while the seals blow. turns out the workingpressure of the 164pump is 100bar, that of a 75 is 130bar! i have changed to a 75 unit at the cost of a considerable amount of blood sweat &tears
-charles-
Bareass
Re: squadragrunn
Post by Bareass »
could you take more detalied pictures of the engine/shock tower brace?
how does it attach to the engine and the chassis at the fire wall and the shock towers?
'84 GTV6 w/3.0
3.0L 24V engine stand!
squadragrunn
Re: squadragrunn
i have extended the bracing in the enginebay to the front and castorballmounts in preparation of a 32mm (hollow) stabi (swaybar)
-charles-
Bareass
Re: squadragrunn
Post by Bareass »
those braces in white look awesome!
'84 GTV6 w/3.0
squadragrunn
Re: squadragrunn
-charles-
squadragrunn
Re: squadragrunn
its been a while, started to clean the car up and change belts
-charles-
squadragrunn
Re: squadragrunn
after i cleaned up the enginebay, i concentrated my efforts on the body, there were some minor rustspots and bad paint.
-charles-
maxiboy
Re: squadragrunn
Post by maxiboy »
Loving this thread... :D
