I've just bought a dynamat hoodliner pack to replace my disintegrating bonnet (hood) insulation. Before I start cleaning, measuring, cutting and sticking, I just want to know if anyone else has done the same thing and if there is anything I should look out for...
Thanks...
Scott in MN
I'm just putting one on to replace the factory heat/sound shield which is falling off and disintegrating, making my beautiful engine and pretty red silicon hoses all dirty! I guess it will do the same job as the original, quieten down the top end engine noise and protect the paintwork from heat. It looks a bit thicker and shinier so might do this job a little better. It is also more available than the original material.
