With the amount of give in 3 rubber couplings, could it be possible to monitor the torque induced difference between the engine's output and the clutch housing's input to give a meaningful torque number at any given time???
My theory would go along the lines of watching the output of the distributor (so nice and even pulses, not the 60-2 CAS) and have the same number of trigger edges aranged on the clutch's input shaft.
Both sets of trigger edges would be aligned so that they trigger at the exact same time (or near enough). And as the engine generates more torque, the rubber couplings would distort more and more, putting the alignment of the engine's trigger and the clutch's input shaft trigger out. The increase in disparity would show an increase in torque.
Now the fun part................
Turning that into useful information
The only/best idea I can come up with, would be to feed the 2 trigger signals into a micro controller like an Arduino and have it output an analogue 0-5 volt signal, where higher voltage equals more misalignment, which means the engine is dishing out more torque. Fead that 0-5 volt signal to a data logger to log against other info (RPM, MAP sensor, TPS and O2).
Bingo! Real world dyno!
Idea number 2 I came up with years ago and is basically 2 versions of the same idea.
2a involves replacing the right hand side engine mount with a load cell. As engine torque increases, it leans harder on the right hand engine mount. Amplify load cell signal to give 0-5 volts, feed to data logger. BAM! Real world dyno!
2b is similar and I figured more realistic.
Replace right hand side engine mount with a small hydraulic cylinder. Fill with oil and seal, tee a pressure sensor into it that gives a 0-5 volt output! Yeah yeah! Real world dyno!
