With a real question mark hanging over the durability of the internals in an Alfa transaxle being able to survive any decent sort of grunt and having seen mentioned a few times (OK, maybe once...........) that having oil pumped onto key areas could help keep things in 1 piece, I had a thunk.
In an attempt to keep it realistic (no ($1200 Person/Moroso pumps here), how about using a small powersteering pump, mounted to the clutch housing and is driven off of the tailshaft, to draw oil from the base of the gearbox, pump it thru a small oil cooler and then sends it to the pinion/crown gear (diff gears) or even an internal spray bar that pumps oil onto all of the gearbox gears, the bearings and the diff gears???
