KevinR
Alternative Alternator Abarth 500, 120Amp for extras
Post by KevinR »
As heading suggests this high powered alternator was necessary as I have now really exceeded the limits of the standard 55Amp . Due to a severe arm injury (in workshop) I have had to fit power steering on the track car which has 225s upfront and heavy castor so steering is a bitch if you got one and a half arms :)
I’m using the 75 power steering rack with a Citroen C4 pump that sits in the boot. This electric pump in the Citroen has already a 70amp fuse !! . I am running two fuel pumps, one been a feeder for swirl pot , heated screens and the usual !
Mate of mine Stavros suggested this alternator and after a few test fit I need to modify my original bracket by 21mm to bring the belts into alignment on my 164 24v based motor .
A new larger alternator cable was needed .
This unit is lighter than the original with built in cooling fans .
I am currently laser cutting the adjusting bracket . Some pics to follow.
Re: Alternative Alternator Abarth 500, 120Amp for extras
I switched to an E500 W124 Merc Alternator. With the Vauxhall PS pump, fan on, it still has 13.8v at idle. I modified the bracket as you did. What about the exciter circuit? Did you just connect it to the alt lamp warning and alt starts charging immediately after starting?
KevinR
Post by KevinR »
I went for Abarth one as lighter . Yes the green wire to original circuit as it’s an exciter for the resistance of the bulb to trigger .
