Carbon fiber driveshaft pics posted
Hello-
I posted some pictures of the CF driveshaft here:
www.realemotorsports.com/driveshaft
I will put some pictures of the shifter up shortly.
Al
Al
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
CF Shaft
Around $1500, not counting the donor driveshaft parts.
BTW, I posted some pics of the shifter, and my pedal assembly:
www.realemotorsports.com/shifter
-Al
-Al
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
- Giulietta24vTT
Re: Carbon fiber driveshaft pics posted
Reale wrote:Hello-
Al
Hi i am realy curious to know how this shaft assembly is holding during a race
as here in the Netherlands one person also made one but with the result of several crankshaft failiours
i think due to misalighnment
At the moment i am building a Giulietta 116 series racecar
with a 2.0 TS race engine
here in Holland we modify the driveshats to use the BMW M5 donuts
Carter Hendricks
I am going to try to attach a photo of an M5 flex... and here is a link showing the M5 flex compared to its smaller siblings. I am also interested in what modifications are necessary.Topspeed wrote:...here in Holland we modify the driveshats to use the BMW M5 donuts
--Carter
http://www.e30m3performance.com/install ... /index.htm
- M5flex.jpg (4.77 KiB) Viewed 16903 times
Carter Hendricks
That was easy. I also saw a photo in a trade magazine of a Prius flex coupling. The design is very interesting! It is a flat machined plate with 6 bushings pressed in.Carter Hendricks wrote:I am going to try to attach a photo of an M5 flex...
--Carter
- priusflex.jpg (23.4 KiB) Viewed 16904 times
Carter Hendricks
I think so. The photo is of a Previa coupling used for the shaft that runs forward from the hidden engine to the ancillaries in front. For another view of the design there is a nice photo on an ebay auction [number 8002272745] which I'll post below. The interesting idea is that the aluminum disc will provide mechanical strength and failsafe alignment while the bushing design can be selected to allow misalignment. I don't think this design would be happy with gross misalignment...Micke wrote:That's a neat design. Should be easy to build too.
I don't mean to double-hijack this carbon fiber driveshaft thread. The CF shaft uses flex joints, of course, and I still want to see more about the M5 coupling solution.
--Carter
- previa.JPG (24.88 KiB) Viewed 16890 times
