Lexan windows for Milano/75
It is my understanding that these windows should save about half the weight of the glass.
Does anyone know of a US source of Lexan windows for the Milano/75?
Alternatively, I have a Euro source that can provide Lexan windows (4 sides and rear) for about $350-$400 at my door (including shipping) under the assumption of multiple sets.
Is anyone in CA interested in such windows, Zamani?, Nizam?, ...
First, you should not use Lexan, it shatters and is not allowed for race cars, probably not suitable for a street car. I have exhanged all glass windows in my race car except for the windshield. The material "brand name" is makrolon and the thickness is 3mm. When i mounted it i did some calc. on it because i had no oppportunity to weigh it all. Roughly 26kg för the glass ones one <7kg for the new makrolon windows.
The biggest improvement is imho that you get rid of a lot of weight that sits really high in the car.
More pictures of my installation is HERE
- PICT0022_001.sized.jpg (115.5 KiB) Viewed 15207 times
Kenth Wiklund
75 3.0 Challenge
75 3.0 Challenge
I looked at your pics, and oddly yours say Lexan. Look at the rear window
The windows are actually polycarbonate, if that makes a difference.
Kunta,
Forgot to ask: Where did you get yours? How much are they?
BTW, yes the whole purpose is to get rid of weight, and as you said, if it sits higher, even better.
Lexan, makrolon or whatever. They are all brand names for PolyCarbonate. Shatterproof transparent plastic.
Try to get scratch proof quality.
Ah, ok. Thanks for the clarification Mats. Is there a cheaper way to do this. I'm not familiar with plastic technology. Is it possible to buy raw material and cut yourself? Even the rear?
ar4me wrote:Ah, ok. Thanks for the clarification Mats. Is there a cheaper way to do this. I'm not familiar with plastic technology. Is it possible to buy raw material and cut yourself? Even the rear?
Sorry, PolyCarbonate was what i was trying to say. i misconfused Lexan with a another material. Mine are sponsored.
Yes they come in sheets and you can shape and cut them by your self quite easy with a little training. Should be No problem for a handy guy like you
Kenth Wiklund
75 3.0 Challenge
75 3.0 Challenge
It's like Kunta says, not difficult at all, woodwork tools does a suprisingly good job.
Ask a regular glass window salespoint, not a car glass place but more a place that sells for shop windows and such.
I agree w Mats. They're all polyC by different names.
The scratch proof can be a lot more expensive - up to 3x, depending on the thickness. If you get tinted/smoked, it will hold up to UV better.
In the US there are many sources. Try MSC and McMaster-Carr for starters. Both catalogs give plenty of spec info too.
3mm? This sounds kinda thin compared w the orig glass. I suppose if it seals up OK it doesn't matter so much.
3mm is minimum for our race regulations. All windowss are sealed with sikaflex (sort of pu-glue/sealing. very strong) and m3 nutsDaveH wrote:...
On the drivers side you could always skip the window and put a net instead
Kenth Wiklund
75 3.0 Challenge
75 3.0 Challenge
PolyCarbonate is perfectly UV-stable as far as I know.
Exaxtly what kunta says, 3mm is minimum (and less expensive), original seals are tossed (weight) and the PC is fixed with rivets or screws and sealed with the appropriate gunk.
Sporttunergtv6
