Gotech Maps upload/download location
Post your Gotech map files in this location.
What file extension types are needed for Gotech? Let me know and I'll allow uploading of those types.
Post files as .txt files in the interim.... example myGotechMap.gtc.txt
Please list specifics on your car with each file upload, in the message body or file description.
Michael
1981 GTV6
1981 GTV6
No worries - I have added .dfi as an allowable extension.
- test.dfi
- (4 Bytes) Downloaded 1497 times
Michael
1981 GTV6
1981 GTV6
alfa 156 gta, relatively std, 6 cylinder
- alfa1207modtrack.dfi
- (7.65 KiB) Downloaded 1409 times
- (7.65 KiB) Downloaded 1328 times
Here is one that is pretty good for a stock 3.0 in a warm climate...
- warm.dfi
- (7.52 KiB) Downloaded 1243 times
- semismooth.dfi
- (7.52 KiB) Downloaded 1216 times
- semitune.dfi
- (7.52 KiB) Downloaded 1218 times
Here is my latest, might be a bit too rich at start up or I might just have too much advance at start up.
- SamsCool2.dfi
- (7.64 KiB) Downloaded 1147 times
246 3.5litre 12v Engine
Engine Spec:
3.5 litre Alfa Romeo V6 engine, using your 3.0 litre donor motor.
100mm forged Ross pistons.
Fully balanced crankshaft, conrods, pistons, pulley & flywheel.
Lightened flywheel.
New bearings throughout.
Custom ground 10.8mm lift camshafts.
Fully ported & gas flowed cylinder heads.
46mm I.D. intake runners, gas flowed, heads machined to match.
Modified head gaskets featuring Wills rings to seal cylinders.
Hi-Flow fuel injectors from later type 164 engine.
Valve seats 3 angle cut, valves cut to match.
CSC tubular exhaust manifolds.
Gotech MFI Pro stand alone programmable engine management system.
Custom made air intake system to remove air flow metre & allow better breathing.
Lightened flywheel.
- 246HP Map.dfi
- Gotech Map 246HP
- (8.03 KiB) Downloaded 1207 times
- Rookie ROX
Someone have a Pro map for a stock 2.5?
I've had a search and can only locate 3.0 maps.
ROCK ON
R~R
ROCK ON
R~R
- junglejustice
- junglejustice
