- Charlie Hood
Starts runs and Stop
The 84 GTV-6 starts, runs for about a minute or? Then the motor dies. It will start again, but only run a moment the dies and won't start again. I have been reading in the archives.
1) I have not done anything yet; I'm going to start with the fuel filter.
2) While I'm at it I am going to change the fuel line in the back. I'm thinking for fabing some metal tubing U bends. What is everyone doing about these sharp bends at pump and filter?
3) Greg mentioned the Crane Cams ignition, does anyone have any experience with this or? If the ignition is the problem, this sounds like a better alternative.
4) This a bit of low buck operation. I would like to put in 3 liter, supercharger and all that but alas….
Thanks and a tip of the hat from ole Charlie
- Charlie Hood
- Charlie Hood
OK! Alfa Vs. Aphids – Alfa Losses! I believe that I have the found the problem, let me know what you think?
1) I have an aphid problem in the tree above where I park the car.
2) The gooey stuff had gummed the windshield wiper.
3) The windshield wiper control on arm on the steering stalk had been bumped on.
4) I’m guessing the draw on the power after about 3 minutes was enough to knock out the FI or?
5) I need to check the fuse to see if it is the correct value, as I would think that it should have blown.
6) I turned off the windshield wiper and started the car and let it run for about 10+ minutes. I have not had a chance to road test it yet.
7) Does this sound plausible?
- Charlie Hood
Well the aphids were NOT the problem after all. I was walking again Friday.
It starts, runs for a while and stops, sometimes it will catch again, sometimes it will not.
I went through most of the items - Temp II, Thermo Time etc.
When I got to fuel pressure, I found the problem. I was losing fuel pressure when it died.
That led me to no voltage at the pump. In the process it found that if I tapped the Combi Relay, it would die. However when disconnected the Combi Relay, and tested, I was not getting a reading at 88b, Hmm now that I think about it I didn’t have the vane in the air flow meter open….
Anyway, any ideas would be appreciated.
- Charlie Hood
Combi Relay? My book (CarDisk) says that I should be getting a reading with the ignition on at 1) 88Z which I do, and 2) 88b which I don't? In looking at the schematics, it would appear that 88b, goes to injectors 5&6 and pin 29 at the ECU so?? how would I get a reading. In the trouble shooting section it says 88z and 88d I have pretty much gone through everything thing that I can. The problem is intermitent, seems to related to the car warming up. Or something is heating up??
chood
chood
Combi Relay
The most frustrating problem I have had to date concerned a failing Combi relay. The car would die and not restart. The relay AND everything else would check out fine whenever I tested it which was rarely immediately after the car would die. Finally I had to have it towed one day and found the relay not doing its job. I suggest you check the electronics following the Bosch tune-up article on this site (at the start page on the left side go Publications, European Car, and scroll down until you find the Dec '95 story). They have you checking from the connector at the L-Jet brain. This allows you to test for any opens or shorts in the wiring harness too. Also clean up all the grounds involved including the bundle on the right head cover and the one from the plenum to the left head cover. If still inconclusive, I would get a known good combi relay and try that. I had to buy a new one but am always looking for a known good one from a parts car to keep on hand. Perhaps you can borrow one from a local club member?
Additional suggestions: probe the connector for the L-Jet from the back so you don't spread the metal contacts open. Disconnect the battery to protect the Brain (weird stuff always happens to me). Clean every contact you can with jewlers files (the small blue handled files from Sears work OK) or fine sandpaper and reassemble everything with a generous smear of di-electric grease.
Scott Shure
Ellicott City, Md
85 GTV-6
Ellicott City, Md
85 GTV-6
- Charlie Hood
- Charlie Hood
- Charlie Hood
Sportuner, thanks for your reply.... I have never had Lodge plugs in any of my 6 Alfa’s since ‘71. I have a new Combi-Rely and the car is running great. However I have not driven very far, as I am not sure that the relay is the problem. It has been so sporadic. That is why I want to set up the limp home option and be able to diagnose the problem while it is happening.
chood
chood
- Charlie Hood
Charlie - how's the relay working out? Was it still just that?
I have been having some electrical wierdness lately myself, but the symptoms, like yours, make it almost to impossible to diagnose without exhaustive testing.
I replaced my combi relay a few years ago, but I might have gotten it off eBay. It was in great external physical condition, but not necessarily new or sound in the inside, I suppose.
Allen
LA, CA
'84 GTV6
Allen
LA, CA
'84 GTV6
- Charlie Hood
Whew, so far so good on the Combi Relay, the old buggy has been running great. I took the old relay apart and it looked good, however when I ran a piece of a brown paper bag between one set of points it did come out dirty, so I'm wondering??? I'm still carrying a set of jumpers that I made up and DMM in the car. I purchased the new relay from Centerline.
Whew these things are really enough to make one want to take a drink once it awhile.
