Oil pressure problems!
Hi guys!
Now that my 3.0QV conversion of my GTV6 is done and I have it up and running, I´ve run in to some problems. I have low oil pressure.
Cold at idle 4 bar. Warm, driving 1 - 2 bar. Warm idle 0 - 0,5 :-/
Thread here: http://www.alfagtv6.com/bb/viewtopic.php?t=88
But before asking some qustions what to do about it, I have to explain the situation, so bare with me.
The 3.0QV engine from the 164 has its dizzy on the back of the LH cylinderbank. Since the dizzy isn´t on the same axle as the oil pump then the gear for the pump is doing 1,5 rotation for every engine rotation. So, there is a higer rotation in the 3.0QV original.
On the GTV6 where the dizzy and the pump runs om that same axle, so I had to put the gear from the 2.5 in the engine so that the dizzy works. That is the reason for the lower pessure!
So now my question is:
Is there anything I can do to get the pressure up, without rebuilding the engine and putting back the 3.0QV gear. I am currently running it on QS 20w-50 Mineral Racing oil.
I now this is a wide area, but I appreciate all the help I can get.
Sincerely Seb
Sincerely Seb
156 V6 24v -98
GTV6 3.0QV-83
156 V6 24v -98
GTV6 3.0QV-83
Have you verified the oil pressure with an accurate gauge (not the Alfa instrumentation gauge)?
Doesn't the Motronic for the 24v 164 use coil packs - no distributor? Didn't realize it uses a distributor
Seb,I concur with Mats,get a mechanical gauge to test-I reckon your pressure is good.The sender units always fill up with oil and dont work as when new.I cant see that a slower pump speed is going to drop pressure.All pumps have excess capacity and bypass excess oil..besides,here the 164 pump has the same volume as the gtv6-dont know about elswhere.........
Barry!
Thanks for your tips. I will get an acurate gauge to test the "real" pressure. I only discovered the pressure problem yesterday. I will also change oil and filter and try to get a new sender unit.
Some say the rotation speed won´t matter, some say it will. Some say the viscosity of the oil will make a differense, and so on...
I just wanna be able to drive my car
Thanks for now!
Seb
Thanks for now!
Seb
156 V6 24v -98
GTV6 3.0QV-83
156 V6 24v -98
GTV6 3.0QV-83
Seb,
The 3.0L should have a low oil pressure sender beneath the original distributor hole. At least I think that what it's for as I don't use it. Hook up a bulb to the sender and see if it lights up or use the hole with appropriate fittings to fit an oil pressure guage.
My 164 12V 3.0L has heaps better oil pressure than the old 2.5 and I used the 2.5 oil pump, sender, etc in my conversion.
David
David
- Low pressure sender.JPG (39.51 KiB) Viewed 11863 times
Ok david, thanks!
But Your 3.0, is it a QV or a regular 3.0? Only the QV:s has the oiljets for the pistons and the different gear for the pump. The regular 3.0´s has the same pump speed as the 2.5´s, if my info is accurate.
The low oil pressure sender your´e pointing to, is it for the varning lamp in the dash?
Seb
Seb
156 V6 24v -98
GTV6 3.0QV-83
156 V6 24v -98
GTV6 3.0QV-83
Seb,you want real life figures here-not just a lamp that inicates on/off..
Fit the master mechanical gauge and see where you are-its the only way..........once you have determined the status you can decide where to go from there.....
David,I know your trying to help,dont mean to shoot you down,mate.....the light indicator probably has a knee pressure of 0.2 to 0.8 bar only-this is no good in figuring out if its a sender unit or the pump and related hardware......
Ok, this is what I will do now:
I got me a MANN oil filter and Selenia 10w-60 oil. This week I´ll get to borrow oil pressure meter aswell, to check my acurate readings.
I hope it´ll nice to me... :-/
I´ll keep you posted.
Seb
Seb
156 V6 24v -98
GTV6 3.0QV-83
156 V6 24v -98
GTV6 3.0QV-83
Tonite I got the new Selenia 10w-60 in and a new MANN filter. After a testdrive it seems everything is up 1 bar. Idle cold 5 bar, warm 1-1,5. Warm @ 3000 about 2,5-3 bar.
This feels a little better. I syill have to check with an extern gauge and a different sensor. Will keep you posted.
Seb
Seb
156 V6 24v -98
GTV6 3.0QV-83
156 V6 24v -98
GTV6 3.0QV-83
