- junglejustice
Speedo Off - 4:10 Box in 3.0 Verde...
Someone please help; I put a reconditioned short-ratio box from a Milano Silver/Gold/Platinum in my US spec Verde 3.0 and now I do 300 mph in 1st gear (according to my dash...)
How do I fix this?
How do I fix this?
It's easy
You need the speedo sender (the box under the rear l/h seat) from the 4.1 car, and swap this with the 3.54 sender you have now.
Also the pick up sensor from the 4.1 box - mounted in the left hand side in front of the reverse switch.
You also need the speedo unit for the dash. The easiest way is to transplant a binnacle from a 4.1 transaxle car!
Hook it all up, and hey presto!
Basically you gotta keep all the speedo parts from a 4.1 transaxle if you do the swap into any other ratio!
Much easier on the milano/75...... If you have a gtv6 you have to do all the above, but do a cut and shut Job on the rear of the original speedo to fit the 75 type!
Andrew b
- junglejustice
Hmmm Thanks. So I can't just change out the sender under the rear seat - I have to do the sender on the case as well as the piece on the back of the speedo as well!?
Ah crap....
How do I identify the senders - they all look identical...
What's a "binnacle"...?
Ah crap....
Yep - all the original parts from a 4.1 box - speedo/sender/g.box pickup - then you cant go wrong!
Binnacle = dash pod or speedo/tacho/dials case....
Have a look here -
http://www.alfagtv6.com/transaxl.htm
Have a look here -
Andrew b
- Mezevenf
Oh dear,
I just installed a 4.1 box into my 75, I dont think the sender is changed and I know the dash is the same.
Wasnt aware of this. Then again, I'm not sure what ratio I had in the first place.
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
NightSpec
I think all the senders and electronic crap are the same for the 3.55 and the 4.10 box on U.S. spec cars. They simply reindexed the gauge on the Verdes. In other words at any given speed the speedometer needle is actually in the same spot it's just that that spot lines up with a different number on the face of the gauge. My dad messed around with a the various combinations of parts on his Verde with the 4.10 box. No combination worked, the only fix was to put in a speedometer from a 4.10 car. Of couse he went back to the 3.55 box anyway so it did not matter.
- junglejustice
I'm working on a similar problem. Just transplanted a 75 box in an 84 GTV6. It now goes very fast according to the speedo.
There is nothing under the back seat on the 75. The 3 wire sender connects straight to the speedo and the mileage calculation thing.
The GTV6 has a 2 wire sender, although 1 wire on the 75 sender is an earth. The senders seem to have different pulse rates.
Has anyone had success with the Dakota SGI-5 signal converter as this may be the easiest way to keep everything original?
http://www.dakotadigital.com/index.cfm/ ... prd126.htm
David
David
David, I've been running an SGI-5 for about a year now and it works perfectly and is simple to set up. I've a 75/Milano box in a GTV6 with original GTV speedo & original 75 gearbox sender.
The SGI-5 is an "any to any" signal convertor, and the fine tune options allows you to set the speedo precisely for your gearing, whichever Alfa box you are using.
So I can get a electrical -> wire transformation in that box? Fantastic...Steve R wrote:David, I've been running an SGI-5 for about a year now and it works perfectly and is simple to set up. I've a 75/Milano box in a GTV6 with original GTV speedo & original 75 gearbox sender.
Hi Jose,
I posted as a specific new thread to make it easier to find if someone's looking for speedo adjustments in future:
http://www.alfagtv6.com/bb/viewtopic.php?t=920
Should fix your scenario.
regards
Steve
regards
Steve
