OrMar
Will Bilsteins ordered for 75 fit my GTV2.0 body?
Post by OrMar »
Or did I make a fatal mistake by buying them ?
Model is B6.
Yes, Mats, I'm looking in your direction. :)
Thanks, OrMar
B6? not B46?
I see no problem either way.
Be sure to remove the awful std bumpstops in the front suspension if you lower it, they are a complete handling-destroyer.
gtv11636
Post by gtv11636 »
I see no Shock Model B6 on Ther web site, Didnt you mean B46 ?
Anyway, On Bilsteins Web site, the Numbers for the "MILANO SEDAN" and GTV6\Alfetta GT\GTV are diffrent. :roll:
btw - they also write on ther web site application guide, that the shocks for alfetta\gtv\gtv6 (HD) are not sutible for use on cars with lowering springs.
Any coments ? :?
Is there any way to overcome this problem ?
OrMar
Post by OrMar »
Mats wrote:B6? not B46?
Actually, B46, you both are right.
I'm not quite sure what you mean by "std bumpstops ?
Are those visible on, for example, http://www.performatek.com/Alfa/bushing ... o/dwgA.gif ?
Thanks, OrMar
Nope, the GTV had a bumpstop fitted to the chassis in between the two control arms, it meets the plate next to the anti-rollbar fixing on the lower control arm.
When you lower the car the actual travel of the front suspension is very limited and can cause very dangerous effects when you bottom out on a fast turn. Remove the rubber bit or the whole sheet metal thing.
OrMar
Post by OrMar »
I gues you mean this little feller ?
OrMar
Exactly.
Zagato
BILSTEINS
Post by Zagato »
Ormar, what is the full number of theshocks that you bought?
Should look like B46-1175 or B46-0465?
gtv11636
Post by gtv11636 »
Mats wrote:Nope, the GTV had a bumpstop fitted to the chassis in between the two control arms, it meets the plate next to the anti-rollbar fixing on the lower control arm.
Extending down the Uprights will solve this problem without taking out the Bump stop, wont it ?
Probably, but you don't need the bumpstop anyway since the dust covers on the dampers from a 75 will have them integrated. Get those for a quick, easy, factory solution.
TS_turbo
Post by TS_turbo »
hmm interesting mod .... lower front whith proper lower arm geometry and high roll center+rized uper arm for camber gain... but how is this done .. i cant eplain to mayself where is balljoint :?
sorry for offtopic :(
what is that mod?
what is that mod?
Maurizio
Post by Maurizio »
Hmm familiar picture
In the pic the balljoint is in the lower A-arm. And the upright is clamped with a bolt. This will only work with 16" or more wheels.
:shock: :lol:
The Wheel is on inside-out?? :roll:
TS_turbo
Post by TS_turbo »
Mats wrote::shock: :lol:
yes to not rub :D .. no problem for clearance .. i have 35mm adaptor spacers 4x98 to 4x100...
Maurizio
Post by Maurizio »
35 mm won't help when using less then 16" wheels.
Haven't treid it but I don't think a car with - ET on the front wheels will be a serious hand full driving. I run SZ wheels on my daily driver and they are ET7 at the front. The car is very responsive to tracks in the road. I would say that ET7 is the max.
Putting the upright/balljoint out of the wheel is not a good idea, I wouldn't like the idea of having suspension parts touching the tarmac when I run a flat tyre.
Saluti,
Maurizio
