HELP GUYS
I still haven't been able to get to the bottom of my problem.
MY car bogs and then surges when the gas is pressed down suddenly. The problem is worse when the car is cold, and often when fully warm it no longer does it.
I'm thinking it's the AFM. Does anyone have one that they would be willing to lend me to check if my hunch is right? I'd pay for the shipping. It would be a big help.
Greg A.
Greg I see that you had another post on this subject where you wondered if the throttle position switch could cause this.The answer is yes it could.Information on how to adjust it can be found at the link provided.This is Greg Gordon's tune-up article.I strongly suggest you go through the article methodically and perform the procedures exactly as described.Not only are you likely to resolve your "bogging" problem but you'll end up with better performance and reliability.
http://www.hiperformancestore.com/techarticles.htm
Yes,
Thats a great page! I've gone through all those tune up procedures. I didn't find any problems. My throttle switch seemed to work in the reverse. i.e. there was no resistance when there was supposed to be, and resistance when there wasn't, but I think that's just the way mine works. So That leads me to believe that the problem is related to the AFM. I've opened it up, sprayed contanct cleaner on the mechanism. Everything looks to be ok, but how can i be sure really?
Greg something is fishy ! "My throttle switch seemed to work in the reverse".I have included the procedures from the AR manual for both the 81-83 "full load switch" and the 84-86 TPS.Which one do you have ?
- TPS2.jpg (33.81 KiB) Viewed 6898 times
- TPS.jpg (46.04 KiB) Viewed 6898 times
- Que Boludo
