pic14
pic15
Murray, I forgot to mention that it once snowed in Johannesburg 25 years ago. You have never seen so many car accidents in one afternoon.
Anyway here are some of the specs
pic 3 Original 1985 GTV 3.0L (only 212 built)
pic 4 Restored 1984 GTV 3.0L ( seven made in charcoal and three fuel injected)
pic 5 was 2.5 now 3.2 GTA conversion
pic 6 was 2.5 then 3.0L twin turbo now 3.3 24v using 3.0l crank porsche pistons on an existing 156 2.5 24v engine.
pic 7 3.3 24v with custom sump waiting to be brocken on a speed bump. Must make sump guard.
pic 13 this side view shows why the bigger bulge on bonnet was created.
pic 14 engine of 3.3 24v runs Haltech with Ap front calipers.
Some new additions to our family . My wife has finally converted and bought a GT. Thats a sign when you know Alfa are starting to make quality cars as she has always been an Audi fan.
The Multipla is my sisters and thats the good old reliable 164 still going strong.
This pic is on a Saturday morning at my folks place before work commences on pulling the 3.3 24v motor out my oldmans GTV. Its got a water leak into the oil. This pic was taken a while ago and we still have not isolated the leak yet.
Engine out after four hard hours.
Another pic of the GT. Anyone figure out what model(engine) it is and why?
You lifted the engine out with old timing belts?? :o
Mats, dont worry I selected the best of my old timing belts. What normally concerns me is the shelving rack it hangs from.
lucass81
Post by lucass81 »
Hey Kevin, how much did that GTA motor cost, how much did you spend to put it in the gtv6 and is it modified or is a std 250 hp?
My gtv6 is slow, compared to my father´s E36 3.2 euro M3, and I will have to replace pistons, cams, etc.... soon. So maybe for a litle more money that I will spend in my tired 2.5 12v motor I can put a 250hp GTA motor, and problem solved.
Does someone know if the top speed limiter of the e36 euro M3 can be deleted without using a chip?
84 GTV6
96 M3
It may be also advisable to check a BMW site for this info.
Hi Lucass, this car has cost to date including buying it about R100000 South African Rand. Check your conversion. Bought the car ten years ago with sixty thou km on clock, only on seventy though now, for R30 000. Bought brand new 164 3.0 24v motor in crate for R16000.(normal cost to joe public would have been about R50000.) Took about a year to figure out and install the motor in my garage at home.(no internet details then and did not want to ask Dawie how to do it as I saw it as a challenge. I ran it on a motronic system with a unichip. I had to make headers , intake tubes, alternator brackets etc. If some one else to to make all these parts it probably would have cost about R6000.
I then decided it was not good enough and bought GTA crank ,pistons, cams for about R10 000 and a Haltec system for R15000 removed motor from car and asked Barry(friend of mine) to reassemble it with the new parts as his experience on multivalve motors was far superior to mine at that stage (and still is). He did a brilliant job on assembly and Haltec installation and runs as smooth as a factory car.
When doing the original installtion of the 3.0l 24v I made templates for all the parts I made and got all the laser cutting for all the flanges, brackets, flywheel spacers on disc so when we did my dads car it took only two weeks to do. and another week for Barry to install the Haltec.
Rest of the cost is brakes ,wheels, repray and minor maintenance.
Personal opinion - if you dont have access to machine shops, laser cutting, good exhaust shop , ECU installers, DONT start this project . Rather stay with the 12v and go big bore or forced induction.
I dont unfortunately keep any of these templates any more to export as it came to costly(freight charges).
Lennart if you are reading this I still have much improved bottom flanges for headers which dont leak(male and female parts) which you can have. Mail me me on private line for your address.
Chears
lucass81
Post by lucass81 »
Thanks very much for the info Kevin. Probably the cheapest way of getting 250hp is supercharging or a single turbocharger setup on the 12v 2.5 motor. The only problem is that a forced inducted 12v 2.5 wont be as reliable as a stock 24v 3.2.
84 GTV6
96 M3
Hi,
Have you seen Greg Gordon's SC setup? I've seen it personally. It's a proven kit. Price is VERY reasonable.
Giulietta24vTT
Post by Giulietta24vTT »
kevin I must admit I'm amazed by the general condition of your cars and the swaps :roll:
Chen S
ex Giulietta 24V Glenwood TT.
