???Barry wrote:Does your car start and idle?
If so,is it firing on all cylinders?
Barry.
It does start and idle.
When i pull the plug wires out, it sounds as if ther car wants to die..
I'll ma have to get the car to someone that knows more than me..
Will ask the Alfa mechanic if he will come have a look, elswise ill have to take the car to him..
Thanx alot for all the help..
s0rr0w unless the hoses were leaking a tremendous quantity of fuel that's not likely the source of the problem.Have your mechanic do a fuel system pressure check.In doing this he should also verify correct operation of the fuel pressure regulator.
- FUELPRESSCHECK.jpg (41.35 KiB) Viewed 5374 times
