Re: Fuel surge tank question
And the "out" pipe is pointing forward? Probably will never be an issue but still.
Yes that's a must. I'll be installing lo press pump in the place of the original efi pump. As for the heat, I hope that thermal wrap should help a bit.ar4me wrote: Maybe you have a separate feed pump?
Me again. For the record I didn't make/design that tank
The internal diameter of the outlet (to the efi pump) is 6mm whereas the pump inlet itself is 10mm. Should i bore that out or it will be ok?
thanks
thanks
Few pics of the low pressure pump (0,24bar 75l/h), still waiting for the new efi pump.
- DSC00782.JPG (58.36 KiB) Viewed 6413 times
- DSC00781.JPG (66.77 KiB) Viewed 6414 times
- DSC00780.JPG (60.19 KiB) Viewed 6414 times
Well it's 12:30 AM here and ...
Honestly I didn't think she was going to start - i mean there ALWAYS has to be something, add to that a 164 alternator conversion - something really had to go wrong.
Ok so final checks, few looks at terminals on new pump, back into the car. First i cranked it for 20 sec to make sure that the surge tank and EFI pump was primed. Everything's connected I turn the key, one rev of the crank... second... third... cylinders one after another fire up and maintain stable idle! After 4 months!
runs smooth, revs excellent. I just need to hook up pressure gauge to monitor how it really works - so far 15 mins of running and everything is good.
Unfortunately theres a micro fissure on one of the welds on the surge tank - will need to fix that.
Heres the pic of still mock set up, but hell it works
Test drive next week, ill let you know how it performs in battle mode
- DSC00800.JPG (70.63 KiB) Viewed 6366 times
OzMidnight
Are you going to insulate the swirl pot at some point?
Non Illigitimi Carborundum
Of course, and headers too.
Nice work, PietereQ! The best of all is that you gave conclusion to this story.
Hey, guess my last post in this topic
But I guess that now after the setup has finally beed tested in track conditons it was designed for, the story should be complete. So NO PROBLEMS setup worked 100%
, finally I could put the power to the asphalt on exits of long/hard right corners, and say bye-bye to the quattro's behind me
cheers,
Pete
cheers,
Pete
