Bruce
Post by Bruce »
Barry - Front donut replacement,almost stock bolt on..BMW 540 (E 39).
Can I use this as a direct replacement for the front coupling?
Bruce,Hi...No, not a direct replacement.Seeing as your in the UK,get a coupling from Ford for the old 80`s Ford Granada(You know,same as the Sweeney??Hahaha..)
Bolt it on and forget about it.
Cheers. :wink:
Bruce
Post by Bruce »
er.. which one? (the Sweeney site lists 2 versions)
Uh,Ok...the old roundish(dont laugh here now)one and the later squarish one,both had the essex v6 engine in them..
Gees,sorry bud,Ill try get a picture... :oops:
Ok,found them..
Bruce
Post by Bruce »
jema
Post by jema »
What must be done to use the E34 M5 hardy in the front of a GTV6 trans.axel?
What must be done to use the E39 540i hardy in the front of a GTV6 trans.axel?
:idea:
/Mattias A
The mechanic at BMW said these usually last more than 100k miles....
Anybody have the answer to Jerma's question...
Bruce
Post by Bruce »
FAO Barry.
I have just tried fitted the Granada coupling to my car, what a pain! No problem going on to the propshaft front yoke but it is just a few mm too small for the flywheel side.
Too small? Pilot dimension or what?
The rubber coupling needs to be dimensionally larger in relaxed position (not mounted), the rubber must be compressed when mounted on the car or it will wear out very fast. The design intent is to never have expanding forces on the rubber, only compressing.
Bruce
Post by Bruce »
It fits the propshaft end OK but the flywheel bolts are too wide (far apart) for the coupling.
They do not have the same PCD? :?
DaveH
Post by DaveH »
Did you temporarily fit a jubilee clamp while installing? I once tried to fit a coupling after removing the clamp....the symptoms were the same as yours.
DaveH wrote:Did you temporarily fit a jubilee clamp while installing? I once tried to fit a coupling after removing the clamp....the symptoms were the same as yours.
Just the other way around I guess?
DaveH
Post by DaveH »
Mats wrote:Just the other way around I guess?
Good point :D
Bruce
Post by Bruce »
Yes Mat. The factory coupling is compressed to fit the yoke but with this one, it fits the yoke spot on but you have to expand it to fit the flywheel.
