Dennis
Post by Dennis »
Mats wrote: What's that, son? I can't really hear you..? ;)
WE WOULD LIKE SOME PICTURES OF YOUR FRONT SUSPENSION, MATS! PRETTY PLEASE!!!
You probably can hear this! :lol:
'81 GTV6 3.0 QV
'91 75 TS (track)
'02 BMW 330i Touring
TS_turbo wrote:Mats your gtv looks extra low in the back too ... how do you compensate
crapy halfshafts angle when back is very low? :?
Can't say I have given this much though. I figured that they are still way, way better then on any FWD car so what the hey. :)
Not like I'm driving it 20 000Km every year either.
Maurizio: True, but if I'm going to change the setup I might as well do something that fixes both the dry and wet setup problem. 8)
Dennis: Fortunately all communication on this board is done through the eyes.
:wall:
Dennis
Post by Dennis »
OK I get it, you're not going to show us your front suspension. :evil:
'81 GTV6 3.0 QV
'91 75 TS (track)
Den,you dont take to hints quickly,do you :wink: :wink: :D :D
Talking of which...I was doing the 20l turbo`s suspension last week and took some pics of an idea Ive had for years but never implimented...
(Check the rush of replies,been done a million times... :D :D )
Wow, upside down ball joint!!
I also like the caliper on the caster arm mod! Does that improve braking? :lol:
Maurizio
Post by Maurizio »
Barry, you forgot the note:
Don't try this at home :lol:
Hey,Im actaully being serious here...left to right and right to left...upside down...It could work.
Z,the caliper is more effective if its tied to a rope and thrown out of the window when wanting to stop..the idea is that with a bit of luck,it will act as an anchor. :wink: or snag on a pole or sumtin... 8)
Let us know if it wors Baz!
I'd be scared stiff to run the OE ball joint upside down. My guess is it will jump out in a (non)suitable place. If it works the only issue is making the taper in the upright.
Maurizio
Post by Maurizio »
Barry, then you're being very brave. I guess you figured that out already but you don't want to use the ball joint in the other direction. You will pull it out of the lower arm or pull the ball out of its housing :shock:
Future upgrade for me, if I get it into my 15" wheels. I would go uniball in a custom housing, same dimensions as oem in the arm in its normal position.
Ps. Was brewing on this one. Need some info, anyone ever tried to put the 5 stud bell on a older gt(v) upright (which fits into 13" wheels). The 75 upright will not fit into a 15" with upside down configuration. Recon the older 13" uprights are shorter. Drill the taper to a straight hole and make an adaptor for the caliper
Please folks, new thread... :wink:
Interesting Barry, but as the others say, don't drive too fast. :?
Dennis
Post by Dennis »
I was thinking along the lines of a tubular chromoly lower a-arm with nascar ball-joints. These are relatively cheap, screw-in, all parts can be replaced, strong enough and fully adjustable.
have a look:
'81 GTV6 3.0 QV
'91 75 TS (track)
Mats, noted.
My post continued in the Race Cars and Track Preparation-Suspension section.
Ok,off to the race cars section for me...kbye.. :arrow:
Thank you for keeping this thread clean. :)
Oh, Barry always keeps his threads clean and I wash mine once a month whether they need it not.. We are clean livin' guys !! :D :D
