hutchensgd
Physical location of the badge on hatchback "GTV6 2.5&q
My car is nearly completed, and I was wondering if somebody could give me the dimensions from the right edge of the hachback as well as the location from the bottom edge.
- GTV6.JPG (66.85 KiB) Viewed 12141 times
Glenn
hutchensgd
hutchensgd
hutchensgd
hello
cant say it to you, the mines as gone years ago....
but ask it on a french forum, numberous owners.
http://www.purassanta.net/forum/posting ... wtopic&f=1
put in the subject: "position du sigle gtv62.5L a l'arriere du hayon"
and the content: 'bonjour, j'aimerais savoir quelles sont les position exactes du sigle 'gtv6 2.5L' a l'arriere du hayon, les dimensions entre le bord droit, haut et bas.
c'est pour le mettre exactement a l'endroit d'origine sur un vehicule concours.'
and i will translate you the answers.
bye
bye
2 stroke addict
Body Exterior
hutchensgd
If you get the correct badge, you don't need to obtain location dimensions as the badge is positioned on the rear hatch by two locator pins that go into holes that are made by the factory.
If the holes have been covered over by body filler, use a good torch and look inside the framework of the hatch on the right hand side and you will more than likely see the bit of filler that has come through the steel work. This will be your pin locator hole. Simply drill it out and you will have the exact factory location of where this badge needs to go.
hutchensgd
Sporttunergtv6
Sporttunergtv6
Sporttunergtv6 wrote:please pardon my standard measurements but the badge is 11/16 of an inch from the right edge, it is 15/16 from the top edge, and 14/16 from the bottom... hope that helps
vittorio
informations sounds the same.
12/16(19mm) form the rigth and 1 inch(25mm) from the top edge.
2 stroke addict
