Michael
Gotech Maps upload/download location
Post by Michael »
Post your Gotech map files in this location.
What file extension types are needed for Gotech? Let me know and I'll allow uploading of those types.
Post files as .txt files in the interim.... example myGotechMap.gtc.txt
Please list specifics on your car with each file upload, in the message body or file description.
Michael
1981 GTV6
SamW
Post by SamW »
This is the stock map that came with my GT unit, this is sort of for test purposes to see if this works, thanks for doing this Michael!
Whoops, .dfi is the extension, I am going to avoid loading it as a test file, I had problems with that the first time JJ & Jes sent me a map.
Michael
Post by Michael »
No worries - I have added .dfi as an allowable extension.
test.dfi
(4 Bytes) Downloaded 1479 times
Michael
1981 GTV6
4agedub
Post by 4agedub »
alfa 156 gta, relatively std, 6 cylinder
alfa1207modtrack.dfi
(7.65 KiB) Downloaded 1387 times
Gotech fuel injection systems
South Africa
Tel: +2711 3978197
Email: louis@gotech.co.za
4agedub
Post by 4agedub »
(7.65 KiB) Downloaded 1303 times
South Africa
Tel: +2711 3978197
SamW
Post by SamW »
Here is one that is pretty good for a stock 3.0 in a warm climate...
warm.dfi
(7.52 KiB) Downloaded 1222 times
semismooth.dfi
(7.52 KiB) Downloaded 1197 times
semitune.dfi
(7.52 KiB) Downloaded 1200 times
SamW
Post by SamW »
Here is my latest, might be a bit too rich at start up or I might just have too much advance at start up.
SamsCool2.dfi
(7.64 KiB) Downloaded 1126 times
JT
246 3.5litre 12v Engine
Post by JT »
Engine Spec:
3.5 litre Alfa Romeo V6 engine, using your 3.0 litre donor motor.
100mm forged Ross pistons.
Fully balanced crankshaft, conrods, pistons, pulley & flywheel.
Lightened flywheel.
New bearings throughout.
Custom ground 10.8mm lift camshafts.
Fully ported & gas flowed cylinder heads.
46mm I.D. intake runners, gas flowed, heads machined to match.
Modified head gaskets featuring Wills rings to seal cylinders.
Hi-Flow fuel injectors from later type 164 engine.
Valve seats 3 angle cut, valves cut to match.
CSC tubular exhaust manifolds.
Gotech MFI Pro stand alone programmable engine management system.
Custom made air intake system to remove air flow metre & allow better breathing.
246HP Map.dfi
Gotech Map 246HP
(8.03 KiB) Downloaded 1190 times
rz
Post by rz »
can somebody supply me a mapping for the 3,7 engine with gotech on sea level?PLEASE
Rookie ROX
Post by Rookie ROX »
Someone have a Pro map for a stock 2.5?
I've had a search and can only locate 3.0 maps.
ROCK ON
R~R
junglejustice
Post by junglejustice »
You guys should also list your GoTech models please! Generationally there are subtle differences between the Standard, the Pro and the new Pro-X which preclude file-sharing of the maps...
rz
Post by rz »
i hope barry will suply you with an answer?
rz
Post by rz »
again double posting :oops:
junglejustice
Hey Bud!
For a Pro or for a Pro-X...?
6 Standard Alfa/Bosch COPs or a 6-pack brick of 3 x double coils (either way - you just need to change that setting in the setup screen however, we still need to be specific - Pro or Pro-X?)
fastcar
Post by fastcar »
4agedub wrote:alfa 156 gta, relatively std, 6 cylinder
Hi 4agedub,
Is it for a PRO v5 unit?
I just received the unit last evening and I would like to install it during the weekend. But it would be great if I should have a good base which one I can fine tune to my readings.
Thanx in advance,
fastcar
