Alfahannen
Road performance and gearboxes?
Post by Alfahannen »
Hi Folks!
I need advice about how to upgrade my cars road handling. This is how my car is set up today:
GTV6-83
24mm Torsion Bars
Monroe Shocks
The flexible cushions on the radius rod are changed to power-flex
The car is far to soft for my taste and I look for a bit more firm handling. How have you been upgraded your cars?
Gearbox:
On which models are the gearbox with "better" gear ratio mounted?
Best wishes,
Jonas
Paul Bird
upgrades
Post by Paul Bird »
Hi, I have upgraded my GTV6 with an alfa 75 twinspark box, this has the added advantage of limited slip diff and better gear changes together with a re-disigned gear lever from Alex Jupe motorsport UK.
The suspension is a coilover fast road set up from Ron Simmons and handles like its on rails. I hope this helps in your quest to find a better drive.
Paul UK
Tjena Jonas
Bilstein shocks
105 caster ball joints
stiffer springs all 'round
Enjoy. ;)
The TS box is by far the best standard box you can fit.
I thought the 75 Turbo had the best box, better driveshaft donuts too.
Turbo 3.9:1
TS 4.1:1
Driveshaft donuts? How would you fit a 75 driveshaft on a GTV?
TurbMarc
Post by TurbMarc »
75 Turbo driveshaft and donuts are the same as v6
I installed TS gear box on my Turbo for better acceleration.
Alfahannen
Thanks!
Thank you all for your replies, it helps a lot. I like to spend my money and time upgrading and improving, not re-inventing what's already is invented.
/Jonas
Alfahannen
Re: Thanks!
By the way!
What parts do I need to be able to convert my original "116" caster assembly to the "105" caster ball joint? I found the parts att Highwoodalfa but are not sure what to order, please help.
/Jonas
Alfahannen wrote:Thank you all for your replies, it helps a lot. I like to spend my money and time upgrading and improving, not re-inventing what's already is invented.
/Jonas
Jose_76
Post by Jose_76 »
You can see it also at www.performatek.com. You just have to order the Caster Rod Ball Joints and its Adaptor Kit. It's a bolt on upgrade :wink:
'84 Red GTV6 3.0
Re: Thanks!
Alfahannen wrote:By the way!
/Jonas
You're Swedish right?
Call up CC-motor and get the parts there, cheap enough and less hassle then getting them from another country.
I made a how-to for the whole procedure on alfapower.nu ( http://www.alfapower.nu/viewthread.php?tid=4565 )
Jose_76
Post by Jose_76 »
That's just the way Mats shows it, but if you don't want to drill the car, you can use a thicker adapter like the ones in the picture. If youwant to do it yourself, take an exhaust gasket for the right shape :wink:
Caster arm kit.jpg (46.05 KiB) Viewed 13540 times
'84 Red GTV6 3.0
Maurizio
Post by Maurizio »
8) The original design of the performatec kit is from me.
I've got a set adaptor plates of the newer design on stock.
Aluminium adaptor for the wheel side and a stainless steel clamp plate for the motor bay side.
edit: inserted picure
Saluti,
M
Jose_76
Post by Jose_76 »
Cool, Maurizio!! :wink:
Are you selling that new kit?
In any case, what's the thickness of the Performatek's plates? 10mm?
'84 Red GTV6 3.0
Maurizio
Post by Maurizio »
I'm not sure what thickness my first design had, think that the drawing I sent to Andy was 8 or 10 mm :?
The new set is 8 mm thick alu adaptor plate and 4 mm clamp plate.
Do I want to sell, don't want to screw up this nice site with commercial blabla :x , I'll do a PM.
Jose_76
Post by Jose_76 »
What's that clamp plate? :oops:
'84 Red GTV6 3.0
