Re: xrad's gtv6
It is a good deal. I will check quality when they arrive. Apparently, these are made in the phillipines, but have a good reputation.
check out:
http://www.rotawheels.com/
check out:
Re: xrad's gtv6
this website is a real PITA. never works on the first try....
Re: xrad's gtv6
It rarely fails me, strange...
Re: xrad's gtv6
trying something new
Re: xrad's gtv6
I changed some IE settings so that IE8 works with this older website(IE7)...including some developer tool changes....will see...
Re: xrad's gtv6
Works for three posts so far...
Re: xrad's gtv6
I'm assuming the Rotas are 5x100 and you're either going to:
1) modify the holes for 98mm
2) Wobble bolts from Serpent
and
3) Get proper centering rings
and
Re: xrad's gtv6
Nope. They are specifically 5x98's with 58.5 center bore and 30mm offset for alfa. These were from special order for alfa wheel distributer.
apparently , he did not need all the sets and two were left over (per 18racing). these were then sold on ebay . I bought one set and the other one sold, too...i think (no longer listed)
So we shall see if i got a good deal or not in a few days....
Re: xrad's gtv6
Alfissimo carry the same wobble bolts cheaper...Zamani wrote:I'm assuming the Rotas are 5x100 and you're either going to:
and
1966 GTV
1982 Suzuki "Bathurst" Katana
Re: xrad's gtv6
DID some engine work converting 164s to gtv6. No one mentioned that you have to drillout about ten bolt holes for the pan bolts. Also, front lower engine cover fits the crank pulley, but needs to be drilled for pan bolts. You can only get 3 out 0f four in place due to casting. Should seal up allright, though..
Received my ROTA rims today.
all I can say is HOLY CRAP, THESE ARE AWESOME!!! They will need a set of deep lug nuts as the capped ones bottom out ...
see pics..
see pics..
- cleaned and ready to go
- IMG_4696.jpg (94.83 KiB) Viewed 7936 times
Re: xrad's gtv6
more pics...blue cause of photo shrink not working right..
- extra holes to drill
- IMG_4700.jpg (88.6 KiB) Viewed 7931 times
- cleaning and honing
- IMG_4699.jpg (87.87 KiB) Viewed 7930 times
- 7 thousandths off
- IMG_4698.jpg (105.13 KiB) Viewed 7930 times
- micro polish..dead on blue!
- IMG_4697.jpg (74.18 KiB) Viewed 7929 times
Re: xrad's gtv6
Rim pics:
total weight for two thick boxes and straps and two wheels is 28lbs...so I am guessing each wheel weighs ~13 lbs.
- IMG_4702.JPG (73.28 KiB) Viewed 7924 times
- IMG_4701.JPG (59.26 KiB) Viewed 7925 times
Re: xrad's gtv6
I like these so much, I just bought another set!
So for the usual price of one set, I have four spares (I tend to drive off the road...)
Re: xrad's gtv6
Very very nice wheelsss, i'll be looking for a set for the Giulie if the price bought here isn't too crazy
Re: xrad's gtv6
They ship around the world (from Phillipines)
